For all of you who want to rebuild this at home.
This sketch controls a 7-segment display as a gear indicator and simulates a keypress when corresponding data is being received through the Arduino's serial port.
The display is able to show: r (reverse), n (neutral), 1, 2, 3, 4, 5, 6
// Eine 7-Segment Anzeige ansteuern
// Matthias Busse Version 1.0 vom 30.11.2014
// 7-Segment a-f und der Punk h
// -a-
// f b
// -g-
// e c
// -d- h
// a > D2
// b > D3
// c > D4
// d > D5
// e > D6
// f > D7
// g > D8
// h > D9
int j=1;
// R N 1 2 3 4 5 6 7 8 9 10 11 12
//byte z[14]={B00001010, B00101010, B01100000, B11011010, B11110010, B01100110, B10110110, B10111110, B11100000, B11111110, B11110110, B11111101, B01100001, B11011011};
// R N 1 2 3 4 5 6
byte z[8]={B00001010, B00101010, B01100000, B11011010, B11110010, B01100110, B10110110, B10111110};
void setup() {
for (int i=2; i <= 9; i++) // 2-9 sind Ausgänge
pinMode(i,OUTPUT);
// open the serial port:
Serial.begin(9600);
// initialize control over the keyboard:
Keyboard.begin();
void loop() {
segmente(z[j]);
// check for incoming serial data:
if (Serial.available() > 0) {
// read incoming serial data:
char inChar = Serial.read();
// Type the next ASCII value from what you received:
if ((inChar == 'p') && (j < 7)) {
Keyboard.press(0x81);
delay(100);
Keyboard.releaseAll();
j++;
segmente(z[j]);
if ((inChar == 'm') && (j > 0)) {
Keyboard.press(0x80);
delay(100);
j--;
segmente(z[j]);
void segmente(byte n) {
// alle 7 Segmente ansteuern
for(int k=2; k <= 9; k++) {
if((n & B10000000) > 0)
digitalWrite(k, HIGH);
else
digitalWrite(k, LOW);
n = n << 1;
Leon Bataille
