20150715
Start of project.
Bought the frame and distrobution board.
20150720
Soldering of the main battery wires on the distroboard
20150725
Bought 4 speedcontrollers EMax 12 A SimonK BEC
20150726
Test fitting the frame and speedcontrollers to see if I could start soldering the powerkabels to the distroboard.
Conclusion:
I need to get cable connectors and engine to be able to estimate the length of the cables before the cut theminto the right length and solder them into place.
20150830
Ordered connectors and LEDs on Hobby King.
20150815
Finally I'v got my MT 2204 Motors and where able to estimate how long the ESC cables where going to be. Then it was all about the soldering the cables to the distrobutionboard.
