Hackaday post
A project log for No battery NFC air pressure sensor
Measure tire or ball pressure with your smartphone
captmcallisterCaptMcAllister 11/09/2015 at 15:380 Comments
November 9, 2015: Whoa! Why didn't someone tell me they wrote up a post. All the sudden the views blew up. :) Glad to hear the comments. To answer the most obvious ones, yes this is a borderline useless project in its current form, but I do hope to make a more mature version someday. The biggest issue is that a full flexible version would cost about $5k up front (and then <$5 per actual patch assembly after that). The second most common comment is to ask why I cut such a huge hole in the tube. This was just for the proof of concept, because the rigid board had to go somewhere - where better than inside the tube? If I hadn't put it in the tube, it would have likely gotten crushed between the sidewall and the tube itself. Again, in a more mature version, you'd probably just need to cut a hole for the pressure sensor port.
