This picture shows a decent gash in the new polished BMS round bars, and that after just one week's worth of intense printing. I'll replace these with hardened chrome coated rods a.s.a.p
A project log for Printrbot Simple Metal - Bed upgrade
I need a larger print area in order to print a printer
That may have been totally my fault. When I was busy reconnecting the setup last night I noticed that I had overtightened the linear bearings on the X-axis... stupid move.
So anyways, I've rotated the X-axis rods slightly so that the bearings contact a different spot on the rod and I've ensured that at least one of the four bearings has a little bit of play, that should last util i find replacement rods.
hope this helps.
Happy printing!
