I have decided to attempt to use the following parts for propulsion:
- Turnigy D2830-11 1000kv Brushless Motor (for moving the propeller)
- HK15138 Standard Analog Servo (for moving the rudder)
- Metal Push Rods M2.2xL300 (link servo to rudder)
- Pin Horns (connect rods to rudder)
- 10x6 Propeller Standard (for air propulsion)
It's intended to 3d print the propeller, push rods, and pin horns eventually!
Neil K. Sheridan
