It works!!! But it oscillates with about 1s period from 250V to 400V (phase to phase) or regulates only partially, reaching 500V. I need to make frequency compensation and protection, and replace temporary incremental algorythm with PID or something better. I will take a notebook to it and make it throw values through serial/USB. If it does not work, i would make basic ON/OFF regulation.
Relay is now switched off by software. Will update schematic after finished.
The temporary test code (that has fixed oscillation, but regulates poorly):
// experimental AC alternator voltage controller
// Uses AC Control V1.1
#include <avr/io.h>
#include <avr/interrupt.h>
#define DETECT 2 //zero cross detect
#define GATE 9 //triac gate
#define PULSE 5 //trigger pulse width (counts)
#define VOLTPIN A0//voltage measurement
#define LEDPIN 13
int i=450;
int voltage = 0; // variable to store the value coming from the sensor
unsigned long oldtime;
unsigned long time;
void setup(){
// set up pins
pinMode(DETECT, INPUT); //zero cross detect
digitalWrite(DETECT, HIGH); //enable pull-up resistor
pinMode(GATE, OUTPUT); //triac gate control
// set up Timer1
//(see ATMEGA 328 data sheet pg 134 for more details)
OCR1A = 100; //initialize the comparator
TIMSK1 = 0x03; //enable comparator A and overflow interrupts
TCCR1A = 0x00; //timer control registers set for
TCCR1B = 0x00; //normal operation, timer disabled
// set up zero crossing interrupt
attachInterrupt(0,zeroCrossingInterrupt, RISING);
//IRQ0 is pin 2. Call zeroCrossingInterrupt
//on rising signal
// initialize serial communication at many bits per second:
Serial.begin(115200);
//Interrupt Service Routines
void zeroCrossingInterrupt(){ //zero cross detect
TCCR1B=0x04; //start timer with divide by 256 input
TCNT1 = 0; //reset timer - count from zero
// read the input on analog pin 0:
voltage = analogRead(VOLTPIN); // synchronous voltage measurement to prevent ripple
if (voltage > 640) i=i+5; // emergency voltage decrease (does not work)
time = millis() - oldtime;
oldtime = millis(); // period (frequency) measurement for future compensation of generator revs/min change
ISR(TIMER1_COMPA_vect){ //comparator match
digitalWrite(GATE,HIGH); //set triac gate to high
TCNT1 = 65536-PULSE; //trigger pulse width
ISR(TIMER1_OVF_vect){ //timer1 overflow
digitalWrite(GATE,LOW); //turn off triac gate
TCCR1B = 0x00; //disable timer stopd unintended triggers
void loop(){ // code
if (voltage > 620) i=i+1; // decrease phase
if (voltage < 580) i=i-1; // increase phase
if (i > 600) i = 600; //limit
if (i < 300) i = 300; //limit
//i--;
OCR1A = i; //set the compare register phase desired.
//if (i<300){i=550;}
delay(20);
// print out the value you read:
Serial.print(time); // write period of AC
Serial.print(" ");
Serial.print(i); // write phase
Serial.print(" ");
//Serial.println((10*voltage)/205); // 10*voltage in volts
Serial.println(voltage); // voltage in ADC units - / 1024 * 5
