I think that we need to create a common repository/wiki database where we can share reverse engineered car information with a common standard, aiming at being able to automatically download a “descriptor” file that can run on an universal software.
This is not as hard as it seems; most of the data is usually extracted as the raw number, multiplied by a number, plus an offset. More complex formulas are not very common but exist and will be handled accordingly.
So, for every car, we have a page that states pinouts, bus speed, misc notes, and all the found messages. Log files can be shared and will be available for anyone to study.
Example page:
Car: Renault Twizy
Bus speed: 500Kbps
Pinouts:
– OBD connector
— Pin 6: CAN H
— Pin 14: CAN L
| Name | Address | Lenght | Repetition rate |
| BMS status | 0x155 | 8 | 10ms |
| Battery pack temperature | 0x55 | 8 | 1000ms |
| Single cell voltage 1-5 | 0×556 | 8 | 100ms |
Message specifics:
0x155 BMS status (10ms)
| Byte 0 | Byte 1 | Byte 2 | Byte 3 | Byte 4 | Byte 5 | Byte 6 | Byte 7 | |
| Name | – | PWRH | PWRL | CSTAT | SOCH | SOCL | – | – |
| Example | 0x07 | 0x97 | 0xFF | 0x54 | 0x6B | 0xF0 | 0x00 | 0x6F |
| Name | Parameter name | Min | Max | Formula | UM |
| PWRH PWRL | Battery power | – | 0x0F00 | (0x7D0-(n&0x0FFF))*16 | kW |
| Instantaneous battery power measured from
the BMS. A negative value indicates charging, either due to regenerative
braking or AC charging connection. This value can be used in
conjunction with BV (0x55F) to calculate current flow. The indicated
power is the total coming from the battery, power consumed by auxiliary
devices is not separated from the traction power. Example: (0x7D0-(0x97FF&0x0FFF))*16 = -752W (charging) |
| CSTAT | BMS status | – | – | n | – |
| BMS unit status. · 0x94 = Initialization in progress; data acquired may not be valid · 0x54 = BMS ready |
| SOCH SOCL | SOC | 0 | 0x9C40 | n/400 | % |
| Battery state of charge. Example: 0x6BF0/400 = 69.06% |
This is just a brief example; the table may need more columns (to define if the message is read only or if we can send it to activate stuff, a method to handle bitmapped statuses, etc.) but it’s just to explain the idea. There will be a standard way to describe requests and responses, and how to handle data spanning multiple messages.
The community will help to converge to a standard way to save log files, develop tools to convert them, study their content and publish results. I have a small collection of softwares I’ve written in these years that I will make available with an open source license. Other options are:
Kayak http://kayak.2codeornot2code.org/index.html
OVMS CAN-RE-tool https://github.com/openvehicles/CAN-RE-Tool
BusMaster http://rbei-etas.github.io/busmaster/
Mastro Gippo
