Good to go to PCB Fab!
Visible components: NAND Flash, LED, 100MHz oscillator, 2MByte SPI Flash, 2x Murata DCDC, Si1143 ambient light sensor, IR LED and decoupling caps,
The boring side: Xilinx Artix FPGA A50T, 10 pin Connector for 0.6mm IDC, Micro-SD Card edge terminals.
Simple 4 layer PCB, no blind or buried vias.
Antti Lukats
