I've installed revision B which uses several different components:
- Pololu high current motor controller has replaced the Open Electrons version
- Replaced the Raspberry Pi 2 with an A+
- Removal of the Analog sensors, including current (this may be added back later)
- Change in chassis
- Replaced the 9Ah battery with a 2Ah battery (this only needs to last the Pi overnight)
Here's a shot of the inside of the chassis. The compass is likely going to have to get moved, I think there is too much EM interference in this enclosure.
