Revision B Installed
A project log for Portable 2-Axis Solar Tracker
A cheap, portable solar tracker to allow off-grid power usage globally.
jay-doscherJay Doscher • 08/16/2015 at 22:34•0 Comments
I've installed revision B which uses several different components:
  1. Pololu high current motor controller has replaced the Open Electrons version
  2. Replaced the Raspberry Pi 2 with an A+
  3. Removal of the Analog sensors, including current (this may be added back later)
  4. Change in chassis
  5. Replaced the 9Ah battery with a 2Ah battery (this only needs to last the Pi overnight)
Here's a shot of the inside of the chassis. The compass is likely going to have to get moved, I think there is too much EM interference in this enclosure.
