In the last months the project has been left to the side a little bit, but last week I started working some more on my spreadsheet to refine everything and separate the equation a bit better.
I also did a bit more research to figure out what transmition I will be using, gear type, ratio, belt and I came to conclude in a 3:1 gear ratio, belt driven obviously (more on that in the description).
See you in the next update,
Félix
