We are proud to announce that LPS Mini will be used by the French art collective quinzequinze in an exhibition later this year. From a technical point of view moving objects (visitors) will be tracked using UWB. Different sounds will be played depending on their location. Magnetometer data from LPS Mini is used to enable realistic stereo effects, i.e. sounds from left will move to the right if the visitor makes a 180° turn.
Dates: 28 to 30 April
Place: 40 Rue des Teinturiers, 80080 Amiens
Web site: http://connexions.npdcp.fr/projets-2016
" Dans un espace interactif et immersif, le public, plongé dans le noir et équipé de casques audio et de smartphones, est invité à se déplacer et à explorer un environnement sonore.
Des questions s'entremêlent et amènent le visiteur à l’appréhender le futur comme un univers des possibles. "
" In an interactive and immersive space, the audience is immerse in a dark room equipped with headsets and smartphones and is invited to move and explore a sound environment.
Questions intermingle and bring the visitor to grasp the future as a universe of possibilities. "
Don't miss it!
