An aluminum high vacuum chamber was just purchased for our project off of ebay. It was only about $100. It has an ID of about 6 inches. It should be very easy to machine and modify. If this chamber does not hold a sufficient vacuum, we plan on adding a glass bell jar over it to hopefully fix the problem.
