Mouthpiece
Made of a strong but flexible plastic, this part goes inside the fish’s mouth and keeps the water from leaking out. It holds the whole device in place and makes sure the water goes towards the gills. It can rotate to prevent tangling.
Sprayer
The main body of the device, the sprayer has a flow control valve to turn on and off the flow of water while also being able to control the pressure of the water to adjust it for different fish.
Connector
The end of the Sprayer, this has a screw that fits into most standard hoses. A quick connect can be added to allow for use with more parts.
aliahsan.syed
Kpodovzky
Josh
Wasim Sahu
