Features:
- Low cost
- Compatible with Arduino UNO.
- On board LCD and GLCD provisions.
- Direct Plugin for bluetooth module.
- Direct Plugin for Relay Board
- Power supply input both AC/DC 9V to 16V
- +3.3V output
- Interrupt switch
- Separate IO connectors for SPI, I2C, Serial
- Uses only 6 IO lines to interface GLCD and LCD.
- Add on adapter for GLCD interface.
- Keypad interface using only one IO line.
- On Board Protoboard
- Fulfills all basic needs of development
- Version 1.0 have FT232 as serial converter
- Updating board with ATmega32 for serial conversion and adding screw terminals on proto board.
Manoj Thakur
Rishi
Forbin
watchzhong
