I wrote a script to generate gcode from Kicad's Gerber and Excellon exports. The script works fine but the feed rate was waaay too high. Broke off an 0.8mm router bit and the boards look awful. There will be a lot of deburring to do, but it'll work. *Sigh*
Alexander Tuxen
