Current source PCBs are drilled
A project log for Bosslike electroplating on a budget
Process tank and Reverse Pulse Current power supply
alexander-tuxenAlexander Tuxen 08/14/2015 at 10:260 Comments
I wrote a script to generate gcode from Kicad's Gerber and Excellon exports. The script works fine but the feed rate was waaay too high. Broke off an 0.8mm router bit and the boards look awful. There will be a lot of deburring to do, but it'll work. *Sigh*
