The conductive ink arrived and I gave it a try. I forgot to thin it, so it clogged most of the 0.3 and 0.4mm holes, but the bigger ones mostly turned out beautifully. From left to right the holes are 0.3, 0.4, 0.7, 0.8, and 1.0mm, in rows of two.
A project log for Bosslike electroplating on a budget
Process tank and Reverse Pulse Current power supply
