A project log for Valify V2 Robot Lawnmower
3D Printed Jetson TX2 based robotic lawnmower aims to build an "smart" robotic lawnmower using open technology
robin-frjdRobin Fröjd 03/27/2018 at 15:080 Comments
Today I did a quick assembly so I could test the drive system before CNC milling the last parts. Very quite drive (the noise is coming from my Raise3D printer running in the background)
I will 3D print a larger pulley for the shaft reducing the RPM even more.
Here is the Pulley design. Diameter 105mm, 80T. This on the limit on what I could fit within the robot. Lets see
105mm pulley with 80T
Profile Sketch for a XR pulley.
Visit http://valify.se for more info of the project.
