key is the application note of the LTC3114. I made a nice pcb in order to be compliant in design.
All documents are located on my site and the schematic/PCB layout can be found here. My layout normally supports a multiturn trimmer on board, but easily it can be replaced by a multiturn potentiometer so you're quite flexible in adjusting the voltage.
Lithium ION
Raushan Kumar
Sagar 001
jeremy.geppert
