Greetings!
Here I have attached a table of condition and set voltages that may be stepped through to perform digital logic operations on a crossbar array. I have checked the results by hand, but have been unable to replicate them in spice (due to a lack of knowledge with ltspice and model creation...) or in real life. Please contact me if you have any applications for my work that are fruitful.
| Logic operation | Comments | A | B | W0 | W1 | W2 | W3 | Q | |
| Invert (A/B) | Clear Registers | Clear | |||||||
| IMPLY (A/B) to Q | Condition | Set | |||||||
| NAND | Clear Registers | Clear | |||||||
| IMPLY A to Q | Condition | Set | |||||||
| IMPLY B to Q | Condition | Set | |||||||
| AND | Clear Registers | Clear | Clear | ||||||
| NAND A and B to W0 | Condition | Set | |||||||
| Condition | Set | ||||||||
| IMPLY W0 to Q | Condition | Set | |||||||
| OR | Clear Registers | Clear | Clear | Clear | |||||
| IMPLY A to W0 | Condition | Set | |||||||
| IMPLY B to W1 | Condition | Set | |||||||
| NAND W0 and W1 to Q | Condition | Set | |||||||
| NOR | Clear Registers | Clear | Clear | Clear | Clear | ||||
| NAND W0 and W1 to W2 | Condition | Set | |||||||
| IMPLY W2 to Q | Condition | Set | |||||||
| XOR | Clear | Clear | Clear | Clear | Clear | ||||
| NAND A and W0 to W1 | Conditiont | Set | |||||||
| Condition | set | ||||||||
| NAND B and W0 to W2 | Condition | Set | |||||||
| NAND W1 and W2 to Q | Condition | Set | |||||||
| XNOR | Clear Registers | Clear | Clear | Clear | Clear | ||||
| NAND A and W0 to W1 | Condition | Set | |||||||
| NAND W1 and W2 to W3 | Condition | Set | |||||||
| IMPLY W3 to Q | Condition | Set |
