Hacksburg
Blacksburg's first makerspace. We're focused on enabling members of the community to complete projects that would otherwise be out of reach.
2200 Kraft Drive, Blacksburg, VA 24060
We're graciously hosted by the Virginia Tech Corporate Research Center, and meet every Tuesday at 7:00 pm in our workspace at 1872 Pratt Drive. To get in, first try going around to the back of the building and knocking on the double doors. Someone will come around to let you in.
We are a 501(c)3 nonprofit.
  • 1 × 80 W CO2 Laser Cutter CamFive CMA-2416k
  • 1 × Combination Laser Engraver/CNC Mill V1 Engineering MPCNC
  • 1 × 3D Printers Creatlity CR-10 S4, Printrbot Simple Maker
  • 1 × Wood Shop Band Saw, Miter Saw, Scroll Saw, Wood Lathe, Belt Sander, Drum Sander, Planer, Router, Shaper, Dremel Tools
  • 1 × Metal Shop Drill Press, Metal Lathe, Tin Snips, Welding Equipment
View all 11 tools
View hackerspace log
Share this hackerspace
jcboysha wrote 06/01/2015 at 19:45 point
Are you all still around?
Ben Weinstein-Raun wrote 06/02/2015 at 04:23 point
Yup! We haven't been updating this page; we mostly focus on our blog (http://hacksburg.org), wiki (http://wiki.hacksburg.org), and facebook group (probably the first or second result for 'hacksburg')
Are you part of a hackerspace?
Create a page for your hackerspace and your members
