I'm jumping a bit through colors, because I've already used green and yellow and the servos are dark blue etc. ... I want to have him look interesting and colorful!
The mounting for the lower lids will be acetone "welded" on, once they are in the right position.
Printed and glued :)
davedarko
I can't wait until you get to the stewart platform for the neck :)
I might blatantly copy that from @James Bruton
Awesome :) Great Job!
Have you tried Sketchup or DesignSpark Mechanical for 3D Design?
Best Regards!
Thanks man! I tried sketchup but found it to be weird (can't put a finger on it though) and I haven't heard of DesignSpark yet. 123D design felt familiar somehow, I got into it fast and achieved what I wanted :)
You're crazy, Dave... Just crazy... ...awesome!
Just curious - what SW are you using for 3D modelling?
i used inkscape to create a svg file to import in 123D design
normally i get along just fine with 122d design but the outlines where too tricky this time
Oh yes, thanks.
