Here we see Ivan in his current form with three segments drawing a shape. His motion is sinusoidal as we imagine a rotary toolhead with carving bit at the end of his arm. The angle of each segment is adjustable by parameterization.
A project log for Ivan the Teambuilt Robot
An e-NABLE robotics project to give hands to those without use of their hands. Designed with your help.
haha - very resourceful!
I'm just playing with options right now. I'll try 45 next. I'm thinking now that, see, I can generate Ivans because I have a 3D printer and some filament. It takes a few days maybe a week at most, but I can make more than one arm. So why not have one arm hold the work and another carve on it, just like a human would do? I think that the 90 degree arm is a bit much and the 22.5 degree arm is not quite enough, so yes maybe 45 on both arms. Let's see that next...
so this is 90 degrees now, the animation on the hacker channel was about 22.5? What about 45 degrees? this way you could get a 0 - 90 degrees arm.
my openSCAD skills aren't that good, otherwise I would try to design something that has a circular joining point on the top and bottom and a weird morphed shape....
Ah yes, nicely described - I see what you're getting at now. Yes indeed we have just that on Ivan as he is designed now because I changed his angle to 45 degrees to see what you were saying. This illustration will help with the programming too!
Well I can't seem to paste the image here - how did you do that? But anyway Ivan does this only with a zigzag not a pure straight. I'll post the photo in a project log so you can see it.
I'm cheating - you can add pages here on your profile site and I use one of them as a picture store - then I copied the link and it auto embedded it.
