SDCard Info
A project log for DIPDuino=(Arduino+ZigBee+OLED+SDCard+SRAM)*DIP32
Arduino compatible, breadboard friendly DIP32 package with ATMega1284RFR2, OLED display, SD card, SRAM and ZigBee on board.
alex-gornostayevAlex Gornostayev • 01/31/2017 at 18:20•0 Comments
I've compiled SDCard Info example with the updated OLED Display Library and it works fin, jut do't forhet to switch SS between the display and SDCard. Here is a sample code:
const int chipSelect = 23;
DIP_OLED oled;
char s[20];
void switch_sd_ss(void)
  //Select CS output to SD Card
  DDRB |= (1 << 4) | (1 << 5);
  PORTB |= (1 << 4);
  PORTB &= ~(1 << 5);
  delay(2);
void out_text(int x, int y, const char * str)
  oled.out_text(x, y, str);
  oled.display();
  switch_sd_ss();
void setup() {
  oled.init();
  oled.clear();
  out_text(12, 10, "SD Card Test");
