int output_pin = 15;
int randNumber;
ISR (TIMER2_COMP_vect)
PORTD ^= ( 1 << PD7 );
void setup()
randomSeed(analogRead(0));
// set LED pin to ouput
DDRD = ( 1 << PD7 );
//CTC Modus
TCCR2 = (1 << WGM21);
//Prescaler 64
//3686400 / 64 / 440 = 131
TCCR2 |= (1 << CS20);
TCCR2 |= (1 << CS21);
//TCCR2 |= (1 << CS22);
//start with an A
OCR2 = 131 - 1;
//Enable Compare Interrupt
TIMSK |= (1<<OCIE2);
//Enable global Interrupts
sei();
void loop()
randNumber = random(256);
OCR2 = randNumber;
delay(250);
davedarko
