program progress
A project log for MMR-70 - cheap radio module
some experiments with the fm module that features an atmega32
davedarkodavedarko • 09/04/2015 at 08:50•5 Comments
So with the help of the code from #Portable Trollmaster 3000 I was able to set up the module in no time. It works on the atmega32 (no real surprise here). I've made some little changes to the program - I set the sending power all the way up with the help of the datasheet and also worked on the following function. This should make it easier to set the frequency.
void set_frequency(unsigned long frequency)
  unsigned long factor = frequency / 8192;
  unsigned int upper = (uint8_t) (factor >> 8);
  unsigned int lower = (uint8_t) ((factor << 8) >>8);
  Wire.beginTransmission(NS731_I2C_addr);
  Wire.write((uint8_t) 0x0a);
  Wire.write((uint8_t) lower);    // lower 0XEA is 90.0 Mhz 77 / 33 for 108
  Wire.write((uint8_t) upper);    // upper 0X2A Change those values to change the frequency
  Wire.endTransmission();
updated function, removed not needed type castings etc. (thanks to @al1 )
  uint8_t upper = factor >> 8;
  uint8_t lower = factor;
  Wire.write(lower);    // lower 0XEA is 90.0 Mhz 77 / 33 for 108
  Wire.write(upper);    // upper 0X2A Change those values to change the frequency
jaromir.sukuba wrote 09/04/2015 at 19:49 • point
Well, the shifting trick could work, but I can imagine that too diligent compiler can optimize the code out, not sure about it.
Alex wrote 09/04/2015 at 18:48 • point
Line 5 looks some wired for me. Why are you shifting it first right and then left again?. Why are you usinf int for upper and lower and not uint8_t or unsigned char?
davedarko wrote 09/04/2015 at 19:16 • point
The idea behind that is to get rid of the upper 8bits, because I was unsure what the casting from long to int would produce, when the long is bigger than the max integer value. The "unsigned int" vs. "uint8_t" is a result of mixing codes :D I'm going to change that, thank you! I'm gonna play around with the casting stuff and check what I need (easier now with a display hooked up ;) )
jaromir.sukuba wrote 09/04/2015 at 19:24 • point
If you want to get rid of upper 8 bits of "bar" (and leave only lower 8 bits) and copy it into "foo" you can do something like
foo = bar & 0xFF;
davedarko wrote 09/04/2015 at 19:34 • point
@jaromir.sukuba interesting! I guess type casting did the trick as well, but this seems like a clean way too.
