As mentioned in the previous post, I've been working a lot on RaspiDrums. A lot of improvements have been made, and as I said, I'm still waiting for the software to be a bit more stable before I publish the changes.
Basically, everything I mentioned in the previous post is almost finished. The biggest thing now is to work on the Sound Processor. When that part is done, I will be able to focus on the hi-hat, and that shouldn't take very long.
Because it's the end of the year, and I have less and less time, I think I will need another month or two to finish that. So end of February, or possibly a bit before that, is the target for a working hi-hat system. As I said in the previous log, the work I'm doing now will be published in another project, because it's now very different, and a lot better.
Cheers.
