04.20.2014 (Kittan)
Got the easy ones mounted on the frame. I'll need to add a second row of rail and figure out how best to mount the bottom 5 screens (making sure to leave room for keyboard arms and accessories), but it should be done sometime Monday. Then I'll need to work on power distribution. Most of these are run through temporary daisychained 12" extension cables and I ran out, hence why the right middle screen is unpowered. I'm almost out of steel -already cut up all my long sections of angle iron - so I might have to actually go buy some. All that was made from scrap pieces I've been collecting for a few years. If nothing else, this project has been really good for using up my junkpiles. Total cost so far (referring to specifically-acquired materials like GPUs and building supplies) is still under $200.
Hopefully one of these days Novak will actually update on what he's doing with the software. The guy's been just as busy, with no updates to show for it.
kittan
