Sharing the files via GitHub located in the below link. Still not completely used to figuring out the ropes for GitHub.
https://github.com/SKHII/ChargerUnit
Of note is that STL files need to be rotated before printing. I will re-upload correctly orientated files later on.
In the table is the Bill of Materials of this project.
Comment | Description | Designator | Package | Quantity | Value |
Res | Resistor | R102 | 0805 | 1 | 330R |
Res | Resistor | R105 | 0805 | 1 | 330K |
Res | Resistor | R101 | 0805 | 1 | 200R |
Res | Resistor | R104, R106 | 0805 | 2 | 100K |
Cap | Capacitor | C105 | 1206 | 1 | 10uF |
Inductor | Magnetic-Core Inductor | L101 | 2520 | 1 | 4.7uH |
Cap | Capacitor | C101, C102, C104 | 1206 | 3 | 4.7uF |
Res | Resistor | R103 | 0805 | 1 | 2K |
Cap | Capacitor | C103 | 1206 | 1 | 1uF |
SS16 | Schottky Rectifier | D102 | DO-214AC | 1 | |
LED1 | Typical RED GaAs LED | D101 | 0805 | 1 | |
MCP1640CT-I/CHY | Start-up Synchronous Boost Regulator with True Output Disconnect or Input / Output Bypass Option | U102 | SOT-23 6 Lead | 1 | |
MCP73811T-420I/OT | Simple, Miniature Single-Cell, Fully Integrated Li-Ion/Li-Polymer Charge Management Controller | U101 | SOT-23 5 Lead | 1 | |
AO3401 | P-Channel MOSFET | Q101 | SOT-23 | 1 | |
USB Connector | Mini Female B Connector | P101 | USB Mini B Connector | 1 | |
XH2.54 | 2 Pin Connector | BT101, P101 | XH2.54 | 1 |
