We start with:
- 2x 50cm table legs
- 2x2 18cm shelf brackets
- 1x 1200x300x18mm board
- 8x screws to mount on table
- 8x screws for board mount
~20 Eur total
The end caps of the table legs are useable for other projects - remove:
cut clamps on shelf brackets:
Remove paint:
Mount on board for correct orientation (90 deg.):
Weld:
Clean up and paint with primer:
