One hole in the corner, 4.25mm from both edges, used to temp. mount the shelf and mark the locations of the other holes:
The holes are symmetrical to the bench leg, but the screw heads are too big:
Countersink...
et voilà:
some bench cleanup /re-arrangement later:
