To combine an eye catcher, a lottery, an example and show off the UML embedded engineering code generation we built a wheel of fortune for our company.
Since the led stripe would simulate the ball running inside the wheel I needed to cut two discs on my DIY router table cut a groove in one of the discs and glue (epoxy) the hole thing to some heavy duty ball bearings (from a car engine)
