A simple breakout board for the Texas ADS1292R Biomedical Front-End IC.
The IC is a dual-channel ADC for biomedical applications and have 24-bits of resolution and up to 8KSPS. There is also an respiration detection in channel 1.
I'm using both channels for signal sampling since the respiration rate detection circuit makes the input 1 unusable in uses other than ECG.
Giovanni Cimolin da Silva
Bulbul
DIY GUY Chris
kooksay
