It has been a while since this project has been updated, so I've started a rewrite in Node.JS and provided a simpler installation path. The goal is to not build a web interface this time - but instead make this much more of an IoT sensor with potential API integration using SQSGateway.
An early version is posted in GitHub, with installation scripts and additional tweaks coming soon.
