DIY Breadboard Friendly SOIC Breakout Boards
A project log for The Devil is in the Details
A bag of tricks and instant hacks that may come in handy when doing electronics
rogeorgeRoGeorge 10/01/2015 at 20:282 Comments
How to DIY a SOIC breakout board, in images:
DIY - Do It Yourself
SOIC - Small Outline Integrated Circuit
The key to this trick is to observe that the distance between two pins is exactly half than the standard 0.1 inch.
Thus, if we split in half a pad from a single side perfboard, then we will get two SMT pads, with a 0.05 inch step.
elias.alberto wrote 03/20/2016 at 05:21 point
Is that blob beside the chip hiding a capacitor between gnd and vcc?
RoGeorge wrote 03/20/2016 at 14:30 point
Indeed, there are two capacitors (100 nF and 10 uF) in parallel with the power pins.
