Toothpick Your PCB
A project log for The Devil is in the Details
A bag of tricks and instant hacks that may come in handy when doing electronics
rogeorgeRoGeorge • 09/06/2015 at 17:42•0 Comments
A wooden toothpick can clean the solder from a hole.
Melt the solder, keep the solder iron on the pad, then stick the tip of the toothpick into the hole while removing the solder iron from the pad. The wood will change it's colour, but the same toothpick can be used many, many times.
It works especially well for single sided through-hole PCBs.
