Sam DEV
Arduino Nano style board for Atmel's SAM D20 / D21 ARM microcontrollers
Simple to use and Breadboard friendly PCB for SAM21D / SAM20D ARM cortex M0+ microcotrollers. Inspirited by The Arduino nano and other boards from hackaday.io.
Inspirations/Credits
  • 1 × ATSAMD21G17-AU 32bit microcontroller TQFP48
  • 1 × LD117AS33TR LOW DROP FIXED POSITIVE VOLTAGE REGULATORS 1A
  • 1 × MINI-USB-SHIELD-UX60-MB-5ST MINI USB Connector
  • 1 × 12.000M HZ Crystal
  • 1 × USBLC6-2 Very low capacitance ESD protection
  • First tests
    Ethon • 11/16/2015 at 15:06 • 0 comments
    After an while we received most of the components and soldered them all together. Now we are testing some of the basic functions and die IO's of the board.
    At the picture you can see the first test, to toggle a LED with a button by using ASF.
    Code:
    #include <asf.h>
    #define LED PIN_PA08
    #define BUTTON PIN_PA09
    void stepup_pins(void)
        struct port_config pin_conf; // create struct
        pin_conf.direction = PORT_PIN_DIR_INPUT; // set to input
        pin_conf.input_pull = PORT_PIN_PULL_UP; // set to pullup
        pin_conf.powersave = false; // set not to powersave
        port_pin_set_config(BUTTON, &pin_conf); // configure pin PAxx
        pin_conf.direction = PORT_PIN_DIR_OUTPUT; // set to output
        pin_conf.input_pull = PORT_PIN_PULL_NONE; // set not to pullup
        port_pin_set_config(LED, &pin_conf); // configure pin PAxx
    void main(void)
        system_init();
        stepup_pins();
        while (true)
            bool pin_state = true;
            pin_state = port_pin_get_input_level(BUTTON);
            port_pin_set_output_level(LED, !pin_state);
  • PCBs arrived
    Ethon • 11/03/2015 at 13:23 • 0 comments
    Finally the pcbs arrived.
View all 2 project logs
