I have several ideas, but nothing I truly love yet.
- Remove the components and reassembly in a more interesting enclosure. I could pack it flat behind plexiglass to be able to watch the brew process. It couldbe shoved inside some 3D printed enclosure, possibly a dinosaur as an homage to QC.
- A bartending robot
- A drink chiller. This would only dispense when a liquid was at or below a set temperature.
- Scrap components for different projects. Turn the pumps into a plant watering device. Turn the water heater into a standalone electric kettle.
- Connect to a local server to send coffee requests remotely, keep usage stats. How much coffee do I really drink in a week? This would be an exercise in IoT programming; I don't see much advantage to starting a brew ahead of time when it only takes 30 seconds to begin with.
- A digital display to adjust water temperature.
- Create a time schedule to heat water up during typical usage times. This would allow long standby times without worrying what might be growing inside the machine.
AndyMac
Ideas:
- Flat plexiglass enclosure with insulation around tubes, calculate volume of tubes and use spreadsheet to estimate flow ratios and standing water time. Allow whiteboarding to be done on enclosure.
- "cups brewed" counter, digital screen for flow, temp, watt-hour counters
- pull heater and connect more powerful kettle heater, use with large resivour for high "peak times" capacity
- solenoid connection fitted to kitchen sink, detects and fills low room temp res.
A system with a large "at temp" and "room temp" res's could be used to build a scaled up dispenser for coffee pots. Push button, 4-8 cups out, auto filling feeder tank, insulated preheating tank, popping off fresh pots and dirty filters.
Or scale it down, reduce the sizes of tubes between tanks, change dispensing settings to run on continuous flow on/off switch. Now it's a handheld hot water tap with a pushbutton interface, that can hold a kcup and dispense into a travel mug on the road. Use a cheap drill as the new enclosure base? Adjustable settings thru menu interface?
Excited to see project logs
