3D Printer
Trying to build a 3D printer
This printer is a Rostock design with a few modifications. The goal is to build in a few steps to make sure it works well and I don't invest too much money up front.
1) Mechanical assembly. Done (barring any tweaks)
2) Motion. Add motors, belts, control boards. In progress. Ultimately, I want to be able to draw something in 2D on a piece of paper to prove that I have correct motion control.
3) Extrusion. This is everything required to melt and lay down plastic. Hot end, extruder, etc.
4) Upgrades. This depends mostly on how the printer performs. Could include a dual print head, heated build plate, heated enclosure, etc.
I decided to go with the Rostock design for several reasons. The concept is fairly simple and straightforward, there is a minimum of parts compared to some designs, and the build area is very large. The two biggest downsides are the more complicated math involved in a delta robot, and the comparative lack of support for this design.
Design based off http://reprap.org/wiki/Rostock
  • Adding the brains and... a problem
    AndyMac • 08/06/2015 at 03:23 • 0 comments
    Step 2: Motion. Time for a RAMPS board! After a lot of hunting around I decided on the "Ramps 1.4 Mini Set" from gadgets3d.com. For only $90 it came with RAMPS 1.4 board, 5x G3D stepper drivers, cooling fan, SD card reader, 2x thermistors, and wiring harnesses. Because this is a delta design, 5 stepper drivers gives me 1 for each axis, 1 for the extruder, and a bonus spare for a backup. If I manage to survive without needing the backup, it becomes a 2nd extruder driver. The kit even came with a ceramic screwdriver for stepper driver adjustments.
    A standard 9V wall power supply was used to power the Arduino Mega, and a salvaged 12V, 4.6A laptop power supply was stripped and used for the RAMPS board. The firmware is [jcrocholl]'s modified Marlin firmware, on github. For control software I opted for Repetier-Host.
    Installed, powered, and apparently running I tried to connect and... cannot. Once the firmware is uploaded to the Mega and the RAMPS board added, the device fails to show up on my computer. I have not had the time yet to troubleshoot this. My hope is that there is an address setting conflict that I can resolve. If there is an issue with the RAMPS board itself it will be much harder to diagnose.
  • Steppers and Wiring
    AndyMac • 08/06/2015 at 03:04 • 0 comments
    Step 2: Motion.
    This post is actually a long time coming, as I did some of this assembly a year ago. I have added gears, steppers, end switches, and RAMPS board.
    LM8UU linear bearings are from vxb.com.
    I had the top bearings on-hand. They are standard skateboard bearings. Order of assembly is shown below. I needed a few spacers to keep the bearing spinning properly and lined up with the lower gear.
    Stepper motors and pulleys were added. Pulleys are GT2, 2mm pitch, 40 teeth, from sdp-si.com. Steppers are NEMA 14 from Adafruit.
    Another issue I found was with the end stop switch mountings. The lower mountings slide right onto the aluminum rods, but there is no way to keep them from spinning. This could be fixed with some sort of clamp, but should be okay for now as long as I keep them pointing inward.
    The print bed is a scrap piece of corkboard and the glass from an old printer. Holes were punched in the cork to offset the bolt heads.
    The 3 axes were labeled, as were the 6 end switch wiring harnesses and 3 stepper motor wiring harnesses.
  • Mechanical Assembly
    AndyMac • 06/06/2014 at 18:22 • 0 comments
    Step one: put together the bare bones of the printer. The plastic parts were all printed from https://github.com/jcrocholl/rostock. I modified the BOM heavily and will post when it is closer to completion and not a total mess. The only missing info was dimensions for the top and bottom plate. Courtesy of a google search:
    A few missing dimensions were hole diameters and the location of 6 bolt holes. I used a 7/64 bit, but the hole diameter is not critical. The missing holes (red Xes) are easy to mark by lining up the motor_end with the 2 existing holes.
    Overall it was a straightforward assembly. There are some small issues I will have to fix later but are not crucial to operation. One of which is that the combined height of the endstop holders, bottom plate, and motor_end is FAR longer than a standard M3 screw. Countersinking the motor_end or bottom plate later on will fix that.
    The carriage and rod assembly takes a little bit of effort, since each side gets two bolts that face each other.
    Linear bearings were attached to the idler ends with zip ties. It is not my favorite method of assembly but it does hold pretty well. (Ignore the wires and belt for now)
    The final product looks something like this and moves smoothly with very little slop, which was my biggest concern with this step.
View all 3 project logs
wmacaluso wrote 04/10/2014 at 12:28 • point
Looks very sexy - Can't wait to see it with the motors on
Jasmine Brackett wrote 05/20/2014 at 18:28 • point
Yes. Really want to see it in action.
Eric Evenchick wrote 04/09/2014 at 17:30 • point
Ooh, a delta robot. Did you print the parts for the Rostock yourself, or is there a supplier for that type of thing? The build area on this looks pretty impressive.
AndyMac wrote 06/06/2014 at 01:46 • point
I printed the parts at work when we had unlimited material for our uPrint
Russell Hay wrote 04/09/2014 at 04:01 • point
your first motion video is set to private. I'm excited to watch your progress, I've just ordered parts to build a kossel based delta bot for printing chocolate.
