Step 2: Motion.
This post is actually a long time coming, as I did some of this assembly a year ago. I have added gears, steppers, end switches, and RAMPS board.
LM8UU linear bearings are from vxb.com.
I had the top bearings on-hand. They are standard skateboard bearings. Order of assembly is shown below. I needed a few spacers to keep the bearing spinning properly and lined up with the lower gear.
Stepper motors and pulleys were added. Pulleys are GT2, 2mm pitch, 40 teeth, from sdp-si.com. Steppers are NEMA 14 from Adafruit.
