It kind of took all day and I need a break. But here it is. The companion board has these features:
- USB to UART
- UART or Arduino
- Robot power switch is Off
- Arduino/UART mode
- Robot power switch is On
- J-Link mode (C programming)
- Battery charging when USB plugged in
- USB 5V present red led
- UART mode green led, off in J-Link mode
- UART Tx and Rx led's
- Charging blue status led
It uses a FT323RL chip so is Arduino compatible, no dongle needed. Plus UART is nice for C debugging. I tested charging and J-Link, works great. When the new robot boards arrive I'll test UART/Arduino.
