I think the comparator is not going to switch without much higher offset voltage. I simulated it in LTSpice (free download, but only has Linear Semiconductor parts in it). The mistake is not fatal, I put in a manual override it case it failed. It's a good example of how it is a royal pain to check every little thing, but it can bite later.
