Pro tip: Make a part placement suction device out of a syringe and a aquarium pump (reverse the valve). Put in a long tip, drill a pressure release hole and clamp it in a panavise. Adjust the height, tilt the panavise to pick up the part, and perfect placement! (disclaimer, I am not a pro).
