Ordered T4 solderpaste instead of T3
A project log for Skoobot
Tiny robot for Hacking and EdTech.
bill-weilerBill Weiler 04/17/2018 at 05:100 Comments
The rule of thumb is to span the stencil aperture by 5 solderballs. My analog switch has a 0.2mm stencil width for the pins (it is a 10-pin QFN). T3 solderpaste largest ball is 0.045mm, so that is less then 5 balls across. T4 is 0.038mm, that fits okay.
It costs 2 bucks more for each 5cc syringe I use, a normal and a low temp solderpaste. I get them from Chip-quik. The bottom line is whether it works for me or not. So we will have to see.
