3 Robots for Makerfaire photo - 5 days to go
05/12/2018 at 08:12 • 0 comments -
Soldering troubles
05/12/2018 at 08:11 • 0 commentsI have 4 robots finished. 2 go reasonably straight, 2 do not. One motor glitches in each, lots of glitches in the 2 that curve around. It seems soldering with low temp solder at 200C makes a good motor. Motors soldered at 350C can't be fixed, only replaced. Doesn't take too long but is tedious.
My explanation that could be totally wrong. Flux removes oxidation from metal (the barrier to metal in solder). Flux binds with oxygen on metal and carries it away. But higher temps increases the oxidation in metal. Flux also coats the site, preventing atmospheric oxygen from binding.
Its actually crazy complex. Flux is 4 categories of chemicals, activator, vehicle, solvent and additives. Rosin itself, has organic acids for activators and vehicles that carry the bound oxygen away.
I don't know the metal of the magnet wire, or the metal of the pin of the motor. Different percentages of metals, and their porosity come into play pretty drastically, plus impurities present from where they are mined. With low temp solder, I introduced silver.
Crazy complicated, with metallurgy and chemistry. It can be understood, but is a deep subject.
First Robot for Sale
05/08/2018 at 23:29 • 0 commentsSo new features are:
- New shell design
- Velcro to hold body on
- Battery with PCM (Printed Circuit Module, i.e. undervoltage, short and overcharge shutoff)
- Upgraded battery from 50mAh to 60mAh
- Much better QA and testing
- Companion board works great, automatic switching between UART and Programming modes
- Professionally glued wheels by Rob Black, wheel gluer extraordinaire
Change of plans
05/04/2018 at 06:20 • 0 commentsPeople said they like following the project, so maybe I will keep posting logs. The next contest is robotic module. I don't see how I could be a module. Maybe enable a swarm? Like Skoobot robots are the hardware modules for a swarm system?
Contest is over
05/03/2018 at 19:12 • 2 commentsI don't think it makes sense to post here anymore. If followers still want to follow, here is a Google+ link I will be updating for Skoobot: https://plus.google.com/u/0/+BillWeilerAll
Open Hardware Contest in Over
05/03/2018 at 18:33 • 0 commentsI wasn't one of the 20 winners.
Kind of interesting
05/02/2018 at 23:11 • 0 commentsLooking at the labels on the package from Shenzhen, I try to do some detective work. Who handled the package, and where? Who did customs and taxes? There is some funny US company, DFS Super Store, that sent the US part of the delivery. They arrived at Los Angles Airport by Cathay Airlines (never heard of them). There is also a WTC Logistics company. It says 174 pieces, likely the larger container my shipment was part of, before they broke my stuff out.
Batteries from Shenzhen showed up
05/02/2018 at 23:05 • 0 comments -
Went to Robogames in Pleasanton, CA
05/01/2018 at 04:02 • 0 commentsHere is my link to all the photos and videos I took: https://plus.google.com/u/0/collection/YnHjZE
Here is a photo of my table. I entered best of show but got my butt kicked.
5 daughterboards made
05/01/2018 at 03:58 • 0 comments
