I will be releasing Stronghold CMD as open source so that you can create your own modifications to the program and add different functionality to the program. It has been designed in a fashion to allow simple feature adding by the use of code modules, easily programmable sections of code designed to execute a specific function. Stronghold CMD is still considered closed source at this time but will be released open source once the program comes out of beta (v1.00).
Setting up a basic instance only takes about 15 min and a few physical parts. What you need to setup Stronghold CMD is a computer or server installed with Windows 7 or Windows 8.1, a set of computer speakers, a microphone that can capture the sound in a room and a Z-Wave enabled USB stick. Full documentation for setting up and installing the program can be found in the downloads section of Stronghold CMD under the Projects heading on www.hobbyware.org
T3rr0rByte13
Doan Hong Trung
zeeleez
