Espruino Pico w/ HC-SR04,ADXL335&TCRT-5000 Sensor
Connect Espruino Pico with HC-SR04 Ultrasound distance sensor, ADXL335 ACCELEROMETER and TCRT-5000 Reflective Optical Sensor
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
Connect Espruino Pico with HC-SR04 Ultrasound distance sensor, ADXL335 ACCELEROMETER and TCRT-5000 Reflective Optical Sensor, display the result of distance, X/Y/Z value in Nokia 5110 LCD, and turn on the LED when touching the Optical Sensor.
