I finally got the drifting problems sorted out! I added a lot of data logging to the code and spotted the switch bouncing when I ran it drawing circles over and over.
[(98)=100][(82)=84][(101)=204][(116)=118]
[(103)<104>=105]
[(0)=183]
[(40)=42][(133)=214][(87)=89][(103)=150]Its not terribly easy to read as I needed the data compact so I could scan through large amounts of it. What is happening though is that each step is taking anywhere from 40-130ms to complete, but then there is a point where the switch fires at 103ms 104ms 105ms after receiving an instruction to move. This means the switch is closing, but then opening and closing again within 2ms.I added some simple code to reject any switch changes that happen too quickly to the Arduino Sketch:
if(millis()-lastclick_millis[axis]<20){
// De bouncing
lastclick_millis[axis] = millis(); Since the normal switch changes were happening at around 40ms and up, and the bounces were all 2ms and less I figured rejecting anything below 20ms was a fairly safe boundary.Then I set my H shape test cutting, and it worked perfectly! Here it is after a quick light sand and a coat of mineral oil, with a 9v battery for scale:
Now on to getting the auto start/stop working and cutting more things!
penleeki
