This is the list of available and planned Hexabitz modules. We will update regularly as things change :)
Module Stages
Each Hexabitz module goes through six different stages from its inception to mass production:
Concept The module functionality is laid out and major components chosen.
Design Hardware design is complete.
Testing Module is prototyped and being tested.
Alpha Initial firmware and hardware are ready for a limited public release.
Beta Expanded public release with production-ready hardware and mature firmware.
Production Module is mass produced and firmware is stable.
Note: Some module names (part numbers) have changed. The list below shows new and old names. When there is a conflict, the old name is listed between parenthesis.
Modules
H00R00
Silkscreen artwork / logo
Stage: Alpha
H00R00-M
M2/M3/M4 mounting hole
Stage: Alpha
H00R00-H
Stage: Alpha
H00R00-MH
Stage: Alpha
H01R00
RGB LED
Stage: Alpha
H01R20
3 x RGB LED
Stage: Design
P01R00
RGB LED
Stage: Alpha
H03R00-B
3.3V / 1A DC-DC Buck Power Supply With Barrel Jack DC Input
Stage: Concept
H03R00-T
3.3V / 1A DC-DC Buck Power Supply With Terminal Block Input
Stage: Alpha
P03R00
Stage: Design
H04R10 (H13R00)
2 x CR2032 Coin Cell Lithium Battery Holder In-parallel
Stage: Alpha
H04R20 (H13R10)
2 x CR2032 Coin Cell Lithium Battery Holder In-series
Stage: Alpha
H05R00-B
1S Lithium-Polymer Battery Charger With Barrel Jack DC Input
Stage: Concept
H05R00-C
1S Lithium-Polymer Battery Charger With USB-C Input
Stage: Concept
H05R00-M
1S Lithium-Polymer Battery Charger With Micro USB-B Input
Stage: Concept
H05R00-T
1S Lithium-Polymer Battery Charger With Terminal Block DC Input
Stage: Concept
H07R30 (H04R00)
Audio Speaker and Headphone Jack
Stage: Testing
P07R10
Audio Speaker
Stage: Design
H08R60 (H23R00)
Time-of-flight IR Sensor
Stage: Alpha
H09R00
Thermocouple Temperature Sensor
Stage: Design
H0AR30
MEMS Microphone
Stage: Design
H0AR90 (H12R00)
Sensor Hub (Temperature, Humidity, Ambient Light, Color, Microphone, IR Motion Detector)
Stage: Testing
H0FR60 (H09R00)
600 VAC / 1.2A Solid State Relay
Stage: Alpha
H0BR40 (H21R00)
3-axis Inertial Measurement Unit (IMU) + 3-axis Digital Compass
Stage: Testing
H10R40
Thumb Joystick
Stage: Design
H12R00-V
Industrial Analog Input 0-10V / 0-5V
Stage: Testing
H12R00-I
Industrial Analog Input 4-20mA
Stage: Testing
H13R70
8-input Industrial Digital Serializer
Stage: Design
H17R00
3A Stepper Motor Drive
Stage: Design
H18R00 (H24R00)
11V / 1.8A Brushed DC Motor Drive
Stage: Testing
H19R20
2.5A Sensored Brushless DC Motor Drive
Stage: Design
H1AR10 (H11R10)
USB-B-to-UART Converter
Stage: Alpha
H1AR20 (H11R20)
Mini USB-B-to-UART Converter
Stage: Alpha
H1AR30 (H11R30)
Micro USB-B-to-UART Converter
Stage: Alpha
H1AR40 (H05R10)
USB-C Mass Storage Device
Stage: Testing
H1BR60 (H05R00)
Micro SD Memory Card
Stage: Alpha
H1DR10 (H10R00)
RS485 Serial Transceiver
Stage: Testing
H1DR20
CANBus Serial Transceiver
Stage: Design
H1DR50 (H17R00)
10Base-T Ethernet
Stage: Testing
H1FR00
Sub-GHz Long Range RF
Stage: Design
H21R00
2.4 GHz Wifi
Stage: Concept
H23R00
Bluetooth V4.0 HCI
Stage: Testing
H23R10 (H02R10)
Bluetooth V4.0 Dual Mode
Stage: Alpha
H32R10
3.3V-to-5V / 1A DC-DC Boost Power Supply
Stage: Design
